DO NOT FORGET TO REMOVE THE AUTOMATIC PILOT BUSHING.BoostsFed wrote:you can transfer your flywheel and clutch over to the automatic motor
so the rb20 xmember is not the same as the 25 and a 25 CAN NOT be mounted where a 20 was installed with its original xmember? If so good to know... I might be in the same boat and trying to just get the 25 motorset.Kamin wrote:well if you get a auto RB25 you are at the least gonna need to get eithre a R33 crossmember or a mount kit from mckinney. the RB20 does not use the same mounts at the 25. the wiring harness' are different. your gonna need one for a RB25 along with the ECU. the transmission and driveshaft will work.
