:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue May 25, 2004 10:08 am
No...the voltage curve is different.
The reason the hacked MAF works @ 3" is b/c the stock sensor retains the stock voltage curve...it just doesn't see all the air coming in, because it "thinks" the ID of the pipe is still ~2.4"...
An example:
With stock injectors and MAF...N/A setup, no boost :
At idle, an S14 MAF may read ~1 volt.At 3500 under wide open throttle, under load, it may read 3.5 volts.At redline, at WOT, it may read 4.8 volts.
With a 3" hacked MAF and 370's...under no boost:
At idle, .8 volts.At 3500 under wide open throttle, under load, it may read 2.5 volts.At redline, at WOT, it may read 3.8 volts.
It's reading less air than what's entering the engine, so it's telling the injectors to squirt less fuel...and since they're shooting too much due to the larger size, it balances out.
Now, Z32 MAF with 370s:
At idle...I dunno, .5 volt.At 3500 under wide open throttle, under load, it may read 1.5 volts.At redline, at WOT, it may read 2.8 volts.
Hope that helps...
- Brian
