Have problem with my 240SX!!!
CleanCutSX
Car: Nissan 240SX SE '93
Just want to warn you, my english isn't as well as I would like!!
So, the problem is, my idle is always at 1000RPM, even if I adjust the idle, the computer reput the RPM at 1000RPM!! Also, sometimes, when I'm rolling in fourth gear at like 55 km/h, sometimes if I release the gas pedal the car continue to gasing, stop, compress, give gaz, stop, compresse, it's ****in a pain in the ***!!!!!
I just went to Nissan and plugged the car on the Consult II, and all runs like it does, exept a ****** bad engine code, Cam shaft positioning sensor!! But I don't understand why the code pop 1 time when a get the car off, and another when a start it!!!
I really need your opinion about that, I don't know what to do, since Nissan just told me they aren't able to found the problem!!!!
neverlift
the high rev could be from overtight or binding throttle cable, check the cable under the hood for slight slack like 1/4" ,look under dash to see if the pedal comes up freely. Nissan dealerships seem to just suck sorry bout that
