Have no Idea please help
infinitidreams20
Car: 1994 infiniti J30T
so yeah i was trying to go home tonight first off freezing cold ha ha yea well it is winter in virgina but any ways i tryed to start the J when it all of the sudden stalled out so i did dimoand told me to do with pullin the injector fuse under the hood turned it over it it tryed then put the fuse back in fired right up but here is the real problem headin out of the parking lot the car loses all dash lights except the radio lights well just the track listing and my head lights are stuck on high beam all the time even if it is in the low beam selection i can turn the lights off thankfully just nothing eles any ideas check under the hood fuses fine check unde the dash didnt even find a fuse for the gagues or anything about the high low beam besides the LT and RT head lamp under the hood any help would be loved thanks
vishesh
Car: '95 Infiniti J30
That's absolutely amazing. I don't think you used any punctuation whatsoever.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
so let me summarize, you tried to start your car, it wouldnt start, pulled injector fuse, and it started.
I wonder if related to your other problem you have a lose connection or something.....
DominickJ30
Car: 1993 Infiniti J30t
Pretty sure you loosened some other fuses while in there...
