evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jun 28, 2007 4:34 am
not sure if the G got the updated engine but assuming the newer G's continued to get the samew engine as the Z then the difference is minimal, the g weighs a little more but otherwise mechanical twins, so I doubt you'll find much difference, the newest Z got the 306 hp rating using the new standard which would be closer to 315 using the older standard measure, the early Z's and G's had only 287 hp so it's gona up about 10% which isn't bad
