have a problem, think its my catalystic converter
scels240
Car: 91 240sx hatch
everytime i rev up past 3k rpms its sounds like something in the exhaust is rattling but im not really surei have the stock exhaust so idkif its the catalystic converter what should i do i heard you could just gutt it out
audtatious
Have you checked the heat shields? Could be a loose bolt
scels240
Car: 91 240sx hatch
no i havent checked that but i does kind of sound like a loose bolt?
audtatious
Heat shields are held up by bolts and if loose they would rattle.
scels240
Car: 91 240sx hatch
ill check it out thanks
audtatious
Hopefully that is all there is. Just crawl under the car and tighten all the bolts as a first step.
jasonsan
Car: 1993 S13hb
your CATALYSTIC converter (hahaha)
u dont need no stinking heatshields
Vegascorbin
Car: 1990 240sx dirt track race car
Cut the guy some slack. We are not all English Majors here. We knew what he ment. We are here to help not pass out grades on spelling or english.
Also the factory put in heat shields for a reasion. Yes, you can run without them, but be sure thats what you want before you just rip them off.
Cone Junky
Car: S13 fastback
BMW e46 328i
Sounds easy enough to diagnose. Instead of wasting time on this forum, crawl under your car and start listening.
If it is your cat, no problem, they make replacements that bolt right in
