have a couple ?'s on my new ca18
zenki-S13
Car: 1990 Nissan 240sx S13
hey guys.i searched but cant find what i need
there are some parts that i dont know what they are or what they go to
what does this line go to? im thinking its for a boost gauge but im not sureand what mounts onto those bolts
what do i hook this to?
and i think this is a knock position sensornot sureif not then what is it and how do i set it?
thanks guys
zombieslider
first pic waste gate bolts to the bolt holes 2nd pic your wastegate actuator(rod) goes to the other one 3rd pic is your cam angle sensor you can down load the fsm on here and it will tell you how to set it properly. This pic should help with those.
zenki-S13
aightsweet manyou just saved me so much hassle.thank you
any clue on what that little line off the turbo is?
CakeEater
Car: '93 240SX w CA18, '08 Titan Pro-4X
There should be a single line off the turbo connected to the nipple on the wastegate actuator. Thats if you want the stock 7psi of boost.
aaronscomp
Car: s13
the 3rd pic is the crank angle sensor it should only go in one way and if it doesn't your key way in your cam is gone
rico05
Car: 1992 RMS13 w/ CA18DET
http://www.nicoclub.com/FSM/misc/CA18DE.zip
Download and read that and you will almost never have to ask a basic question ever again.
boost_boy
If you leave that CAS in that position, I promise you 4 cracked pistons. I would be extremely worried about an engine that came to me with that CAS clocked in the position that it's in.
Dee
zenki-S13
thanks for the help everyone
boost_boy wrote:If you leave that CAS in that position, I promise you 4 cracked pistons. I would be extremely worried about an engine that came to me with that CAS clocked in the position that it's in.
Dee
the CAS wasnt in that position when i got it. the bolts werent tightened down.im going to find out what to set it at with the fsm
