Have a couple question about turbo and 1/4
w1ngzer0
Car: Pfft. i don't own a box
Ok question one1.)Could i get a turbo kit for 1500 or under??2.) what would i run if i got an under 12psi turbo?
red240ne
Car: mmm...donuts
1. no2. 13's if you know how to drive. you won't get 12 psi out of a cheap turbo setup anyways. you could source the parts yourself for under 1500, but not a kit.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
1) Maybe, probably not. If so it will be all used parts and will take some ingenuity, and you'll do all your own work (which is best anyway, IMO).
2) Depends on the turbo. A Z31 T3 at 12psi may get you 250-260rwhp, which should get you to mid-13s @ 103-104. A T3/T4 at 12psi (you'll need bigger injectors, etc...) wil get you maybe 290-300rwhp and low 13s @ 106-108.
1/4 times are just guesses, it depends on the weight, chassis, tires, and driver...
Later - Brian
w1ngzer0
Ok thats good im just compairing a KA24E to a SR20 it seems the KA24E would be the better choice for my buck ;)
