so far i have replaced the dizzy, coil, ignitor chip, double checked my timing, checked fuel pressure and to see if the injectors where spraying, i replaced the tps, the maf and gone thru my wiring. i cant seem to figure it out.. any ideas???? dizzy plug wires where cut by the previous owner but resoldered and ran fine before i blew the motor.. all the wires are still attached..
also im only throwing code 55 (no malfunction)
thanks
