gumby »
https://forums.nicoclub.com/gumby-u10614.html
Mon Aug 02, 2004 12:38 pm
i believe its the same from 89-93 so youre good to go
push the center of the plastic bolts in or youll break em like me
its possible to remove the wiper hatch harness without cutting any wires. really all it took was a little manipulation to get the connectors through. suggest tying some fishing line on to each as a precaution before pulling em through but i didnt have any problems.
Nissan article DIY: Replacing Your Rusted Hatch says to cut them. this isn't necessaryalright, getting the wiper harness fed back into the new hatch is a pain in the arse.
wear latex gloves unless your retarded like me because theres grease all over the harness.
new hatch didnt have wiper so i cut and sealed certain wires but principles the same.
-weed wacker line works best -thread line through the hatch in a loop-split harness wrap all the way up.-wrap connectors to line with duct tape and pull through one at a time to avoid getting stuck-viola done
tried em all at once, not happenin
you need to stick your hand in there if it fits to feel around for it. theres a couple screws to remove so you dont cut yourself.
