Cabezcoco wrote:I had the same problem and it was comming through the tailights. Caulk those bad boys up and the reverse lights. Solved the problem for me.
yeap, it's covered in
http://www.240sx.org FAQs section for using window-weld strip of windshield sealer to re-do those things...
my leak was same as vancouver's
Quote »mine leaks through a metal seam. i assume the seam was welded. use a flashlight and touch to detect the water.[/quote]it looks like it was a brush on epoxy over the seams back thurr... i've seen it in various makes/models besides nissan
