Hatch Trunk cover Questions
itsmexicangio
Car: 1992 240sx SE
hey guys im back on nicoclub after not having a 240 for a few years anywho i have a s13 and im planning on restoring the car with only minor upgrades but does anybody know what these parts are called or where i can get them i attached some pictures with arrow indicating what parts im looking for any help would be appreciated ..
my rideeeee
The_caveman
Car: 93 nissan 240sx hatch(daily build)
1992 Coupe (drift build)
1990 240sx hatch(wrecked slut)
2008 hyundai sonota - girls car/reliable! i drive it better tho ;)
No clue what they are called but go to your nissan dealer ship and describe the part and what area it's in. They will then print out a sheet for you with a picture of that general area with all the parts and part numbers.
Point out the part you need on said sheet and they do the rest of the work
itsmexicangio
Car: 1992 240sx SE
thanks, i was leaving that as my last option, hoping someone knew a DIY or cheap online store
The_caveman
itsmexicangio wrote:thanks, i was leaving that as my last option, hoping someone knew a DIY or cheap online store
Never rule them out as the last option when it comes to small items like that, oem will always make you happy. + they are probally cheap. My pivot point and rubber dust boot for my trans cost like 16$ for both, those should only be a couple of dollars.
.... Now my clutch fork different story 40$, was well worth the money when I got it though
itsmexicangio
Car: 1992 240sx SE
yeah your right! now if i can figure out why my rear speakers don't work ill be set ha!
DanThaMan
Car: 1993 240sx
if you have a factory amp hooked up still, it's probably your problem. check out the link below, worked wonderfully for me.
successful-s13-rear-factory-amp-bypass-t52883.html
itsmexicangio
Car: 1992 240sx SE
ok thanks DanThaMan i have few other questions about the rear speaker set up and all but ill just head over to that topic you linked thanks again for the help !!!
Michaelmoore
Car: '91 Hatch
[79910H] HOOK-REAR PARCEL SHELF - 240SX (S13) These go into the holes in the first picture, and are also what you are holding in the 3rd
Bought some from Courtesynissan, ended up paying $16.77 after shipping, so dealer might be better option. Was only $7.22 before shipping.
The thing in the second picture is where the cargo cover clips in and is the actual pivot point.
itsmexicangio
Car: 1992 240sx SE
Michaelmoore wrote:[79910H] HOOK-REAR PARCEL SHELF - 240SX (S13) These go into the holes in the first picture, and are also what you are holding in the 3rd
thanks ill hit up a dealership on monday thanks for the help !! :bowrofl:
