Hatch release
Toahk
Car: 97 ....
Ive had 2 240's, and neither of the trunk release's work. Is there a way to fix this, a broken wire/cable, some type of spring that has to be replaced? This if for a fastback btw..
BuudWeizErr
I hope so.. Mine doesn't work either. I have to lift it up while holding the latch up with the seat belt.
Toahk
Car: 97 ....
hey me too, I usually use a pen though to hold the latch up.
fiznat
Car: Grown up :(
hahahaha you ghetto mofos.
why not have a friend see if the mechanism is moving when you pull the lever... if it doesnt move then you have some sort of cable problem, if it does move then maybe your lifters or the springey thing that pops it up is busted.... process of elimination?
driftaholic
Car: '91 Nissan RM S13
take off the trim panel from around the side of the latch that has the cable going to it (not the side that's on the hatch lid), unscrew the two 10mm nuts, and move the latch up or down and see if it works better. i had the same problem and after i slid mine down it worked perfectly! then i snapped one of the studs off of it so it always slides around and now it works even worse. i need to get a whole new latch now :mad:
red240ne
Car: mmm...donuts
yea, everyone i've ever talked to has always had hatch problems. they should have been a recall!!
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
my hatch works great thankfully :)
BuudWeizErr
My cable isn't broken, the hatch just doesn't popup when I pull the lever, I have to hold the latch up and then pull up at the same time.
Also, my lifters work beautifully, thank god.
