I've just inherited a '96 300ZX from my dad, which was sitting in his backyard for about three years. I've worked on motorcycles before so I've fixed several small problems with the Z, and now I'm starting in on some of the exterior problems.
Also please forgive me, but I've not been able to find much about these issues, especially since a lot of the older posts having images that are no longer hosted are kind of driving me nuts.
The most annoying problem with driving over even any small bump is that the hatch just shakes rattles like HELL, and it also doesn't pop up when you unlock it, it just sits there until you lift it with your other hand.
The interior plastic material is cracked on the top and the bottom, presumably from the hatch continually slamming into it.
Anybody able to point me in the right direction?
Thanks guys
Edit:
I lowered the hatch lock in the truck, and it doesn't rattle nearly as bad, but you REALLY have to slam it for it to shut.
Also, it still doesn't pop up when you unlock it. It just sits there and you gotta lift the hatch using the fragile plastic -- which my dad just had replaced right before he stopped driving it -- from years of lifting it from that black shiny plastic molding.
