Hatch Problem
rocksteady_racer
Car: 90 240sx Hatchback (Manual - boosted soon KA24e)
Ok so my hatch is stuck shut and I can't figure it out. I even tried pulling on the cable manually and it still won't release. Can I just unbolt it maybe and try to fix it that way? It was a progressive decline in it working. In the beginning, I had to hold the lever open while opening the hatch because the guy before me bolted it up wrong. So I rebolted it and it slid down again after a month. So I figured it be fine for a while til I could get somebody to hold it up for me. Any help would greatly be appreciated. Thanks in advance.
S13Joe
Car: 92 Coupe
The cable may have gotten disconnected. Take the lock out and check it out, same thing happened when I had my hatch.
rocksteady_racer
How did you get the lock out with the hatch stuck closed? The cable still has tension cause I pulled it by hand so I figure if I got disconnected it wouldn't have tension but you have more experience than me so more description would be great. Thanks for the fast response
