Here, posted again... Read these posts and dont be so quick to get on the defensive.blacksrjdm wrote:Also, Its more then a hole in the roof. The area around the roof has a tapered lip, then there is the mounting points, which are welded to the roof support, drain lines, headliner, yada yada yada.It wont come out right, unless you buy a roof section and cut/weld it in.
IBTL.
he's asking if power moon roof and manual sunroofs are the same size. all you're doing is describing what a sunroof hole consists ofblacksrjdm wrote:
Seriously man, you need to learn how to read and interpret because you are obviously the one who is not understanding. I wouldn't get defensive if you didn't act like a prick from the start for no reason.Thanks anyway.blacksrjdm wrote:Here, posted again... Read these posts and dont be so quick to get on the defensive.
Thank you!! Thats all I needed to know.White Comet wrote:he's asking if power moon roof and manual sunroofs are the same size. all you're doing is describing what a sunroof hole consists of
stripes- the power moon roof is smaller so it would take a lot of work to convert from manual to power
What about this didnt say that it would be complicated???? It says right above there that the best way to do it is to cut out the roof and weld in a used panel. I have tried to be decent about this and I found all of the info that I am telling you from other threads about this subject, and by searching.blacksrjdm wrote:Also, Its more then a hole in the roof. The area around the roof has a tapered lip, then there is the mounting points, which are welded to the roof support, drain lines, headliner, yada yada yada.It wont come out right, unless you buy a roof section and cut/weld it in.
IBTL.
Of course they are different. The power setup is going to sit more flush in the closed position. Which is the reason for the tapered edge and the difference in hole size. If you are going to do this then also involved is...Stripes wrote:So the power sunroof roof panel is actually different than the pop up sunroof roof panel?
blacksrjdm wrote: then there is the mounting points, which are welded to the roof support, drain lines, headliner, yada yada yada.It wont come out right, unless you buy a roof section and cut/weld it in.
