EvanW »
https://forums.nicoclub.com/evanw-u216081.html
Thu Apr 18, 2013 4:39 pm
Thanks Ace,
looking over the diagram and comparing to mine it seems that all my wiring is in place and working properly. It must be something mechanical in the latch itself. If you pull yours off and use a screwdriver to "lock" your latch, does your switch arm swing away from the contact? If it does, then mine has something broken inside the latch assembly that won't force the arm to break the contact and therefore the circuit.
Thanks for looking,
Evan
