Postby
phroze2001 »
https://forums.nicoclub.com/phroze2001-u23109.htmlThu Mar 23, 2006 3:23 pm
I just bought this 240 seemed to run great... I drove it home turned the ignition off then immediatly tried to start it, it started fine.. When I leave it alone for about ten minutes after driving it I go to start it and it just sputters and sometimes i can hold the gas pedal to the floor and it will run like s*** for about 15 seconds then it will run just fine. I have replaced the MAF.
Postby
180fan »
https://forums.nicoclub.com/180fan-u3602.htmlSat Mar 25, 2006 10:41 pm
your tps could be on it sway out. check the injectors as the injectors could be having some issues, check resistance and they should be about 14ohms (iirc).
