has this ever happened to anyone?
lilvtboigotrice
Car: 93' 240sx Hatchback SE
Have you guys ever had a problem where you're driving normally and as soon as you brake your steering wheel tilts to the left a little? I usually have to counter-steer barely to get the car to drive straight. This is only when I fully depress the brake pedal. Any suggestions or thoughts? thanks =)
Axel Grungy
Car: 2001 G20 5spd
take your front brakes apart. sounds like a caliper is sticking.
mouse
Car: CARS CARS
maybe a caliper. I had the same problem, it was the tires being real bad. Also could be an alignment, check out all those things first.
lilvtboigotrice
thanks im going to try those out and give the results once repairs are finished ^_^
