ShouldaHadaV8 »
https://forums.nicoclub.com/shouldahadav8-u145112.html
Wed Nov 10, 2010 8:15 pm
IT STILL RUNS ,timing is right,((((( the battery didn't have enough cranking amps....lols )))))
I didn't get time to do compression test but I will soon.
I'm now confused back to step one, but atleast nothing has really changed it still runs just like the video. I've been looking at buying a new car recently because its hard between me and my GF having one car, I've got about $3000 cash im thinking about getting the LS1. But if I can find out whats wrong and fix it .....we're gonna have another KA-T rolling around, which would make me really happy after all this effort, I would hate to part out the motor.
I cant find vacuum leaks Only one i know of is from intake mani. to the FPR, i replaced the coolant temp, tps, o2,knock senors, ECU, both engine bay harnesses,FPR,fuel pump,fuel filter, fuel lines, I tested the MAF sensor, injectors ( no leaks).
I dont know if a Bad piston ring would even make it run like that? I thought about replacing the pcv valve but i've never heard anything about them either? It sucks because i have the money to fix the problem what ever it may be ,but I dont know what else to do????? the only wiring I haven't replaced is the dash harness and body harness. I thought maybe i dont have enough ground wires but continuity is 0.00 at every ground so IDK. I've been asking this same question over and over again for almost a year
