You want to replace the hangers, transmission mount and seals for sure when you do this.
BEFORE you do this....... Just some thoughts depending on your budget.
What transmission are you putting in? 92? Have you condidered a JDM(JSPEC) transmission? You can pick a good used(25,000 - 45,000 miles) one up for $300 - $500 shipped.
Have you considered a Valve job from IPT on the transmission you're putting in? A Valve job on the valve body will help increase pressure giving you harderd criper shifts instead having the clutch constantly slipping for comfort. Your new transmission will last longer.
http://www.ipttrans.com John is a good guy who can do the job on a U.S or JDM Valve body.
Make sure your replacement transmission has the sensor wiring attached to it as mine was all cut off and caused delays if not while installing and a couple extra bucks.
Add transmission cooler. Take Your time!!! Chech your Drive Shaft!
red
