awdjdmtalon wrote:And they come w/ front camber plates which is a plus.
Um, it does in the front?C-Kwik wrote:
The G doesn't have struts. Camber plates would not be able to to have any effect on suspension geometry...
EZcheese15 wrote:Um, it does in the front?
Ah, ok. I suppose I just wasn't on-par with the correct definitions of each.C-Kwik wrote:
Nope. It has a shock and spring in a coilover orientation. Struts bear lateral load. Shocks do not. The shock and spring in the G only see loads that act along it's axis. You can add adjustable plates, but all it will do is change the angle of the coilover. The angle of the wheel will remain the same.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
