Has anyone use "Blazt" program on consult port of your rb?
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
What kind of readings did you get for O2 sensor? mine says 30 when cold and 32 when hot and doesn't vary at all when i hit the throttle.
In the 300zx the O2 sensor data varies a lot when I hit the throttle.
Also 300zx will tell me the power steering pump is ON when I turn the wheel, the rb20det won't. It has the register for it though, so I think it should be.
Anyone have any insight into this?
BTW, ECU is returning code 55, which is everything normal.
Vkoslak
blazt is resold "Datascan 1.4" in case anybody is wondering. No hicas diagnostic wire hookup on my consult to pc cable though!
burnin240sx
I use it all the time. its a freaking awsome tool. when i wire up the harness I wire in the consult port as well. it beats stating up a customers motor blind. plus it help when timing, diag, and monitoring.
the o2 readout is just a percentage of value becaue the sensor only read 0v-1v. it should jump around when rich and lean condtions occur.
as for your PS your harness may not have been wired in for the PS idle up switch.
Vkoslak
I already figgured out the PS bit. I had not wired up the switch. The o2 readout started jumping around once I put the engine under load. So I guess it is working ok too.
Thanks!
NewKleer
Car: Aus N14 Pulsar w/W10 SR20DET
value of 0.3v (stead) normally indicates o2 sensor is dead, value of 0v normally indicates its not connected (from memory)
Vkoslak
Thanks, I have already bought a new o2 sensor, and with the turbo out, now is a good time to put it in
