Goose93 wrote:If you look at other bi-turbo cars like the Z32 and Audi S4 you can see that using two smaller turbos is a very effecient way to produce power. Although you only have half the engine pushing each turbo, you have less rotational mass per turbine. This will allow a faster boost gain over a similar flow single turbo design.
Hypothetically: two t25's can spool faster than a single T51 and produce similar power
An example that can be more closely compared to my idea would be the RB twin turbos. The RB is regularly converted to a single turbo for peak power, but is usually upgraded with dual turbos for racing. A big piece of this puzzle is the area under the curve. By using two instead of one you spool earlier creating more low down torque.
This is why I am researching the idea. It is entirely possible that I am nuts, it doesn't work well, or even at all. But if it does I want to find it and see the details. I am still limited by the SR itself and how much boost can it handle (although this may be a great idea to utilize the displacement of the KA). However if I can get boost at lower RPM's and still carry it to cut off I will make a very potent racer
You can't compare a Z32 turbo setup to an S13 setup. V-6 needs a twin setup, one for each bank, while the S13 is an I4.Dori Dori wrote:You are backwards. Twin turbo setups cannot run very high boost levels and they create more heat at high boost levels. Consider that with a twin turbo setup, you are generally using smaller turbochargers which inherently create more heat at lower boost levels than larger single turbo setups and are way out of their efficiency range at higher boost levels. This is why in the JGTC, when they they used I6's that were originally twin turbo from the factory, they used large single turbo setups instead of twin...higher psi at higher rpm w/ greater effieciency and lower heat levels (probably also for less points of failure too).
tenkawa_akito wrote:The only time I've heard of a single turbo system on a V engine was porsche from way back in the days of F1 racing (the higher ups restricted dual turbo setups in hopes that things would go N/A. Porsche didn't like that
IvoryJ30t wrote:ive given up trying to convince people that twin turbos are beneficial in engines with two cylinder banks just to simplify installation and plumbing.
running two turbos off of an inline 4 is just retarded. your creating this plumbing mess just so you can say you have twin turbos, and in the end its gonna cost twice as much money to achieve the same power as a good single turbo.
tell you what. go twin turbo an SR, and come back and tell us how much money you spent, and how much it sucks.
tenkawa_akito wrote:I don't know if the JGTC has switched to using the new skylines or if they continue to parade the old GT-Rs. But if its the new skylines, they run the same V engine as the 350s, so there again, you have the argument it's best to run a dual turbo setup because of the engine design. On older GT-Rs, it's been common practice to dump the dual turbo design in favor of a larger single turbo.
i might have misspelled it. heat gained or lost from compression or decompression of gasses.Def wrote:Just have to ask, what were you meaning when you used "adiabatic" in that sentence. Adiabatic means zero heat transfer across a system boundary(which is arbitarily choosen).
I keep rereading it and I'm not picking up what you're putting down... Are you referring to compressor efficiency? That's not at all related to the term "adiabatic."
Just an FYI if that's what you meant. Figured at least some edumacation in this thread might be worthwhile, since it seems some of our explanations are falling on deaf ears.
