Has anyone tried to put in 14 in wheels on their 240sx?
voltes v
Car: cars, anime, 240sx
What are the advantages or disadvantages?
240marcuSX
Car: E34 525i
E46 M3
uhh
advantages - lighter, easier to spin, cheaper tires
disadvantages - easier to spin, might be ugly, traction issues, not bling.
there is no "trying" to put a 14" wheel on your car, you just find one that matches up with the hub, and has the correct bolt pattern and offset, and put it on.
sultan
i run 14s, but that's because it's the only full set of wheels with good tires i have. 14x6 with a +10 offset or something like that, tires are a little short, 205/60-14. it gives the car some fender gap even though my car is dumped. with 16" gram lights with taller tires there was no fender gap, it actually tucked a little. when i turn hard there's not much bodyroll (coilovers, sway bars, stbs) but i can feel the tires rolling over because of the massive sidewall.
there's one nico member who was talking about getting some 14x8's for the front of his S14, don't know if he did yet.
aither
Car: Rock Climbing
even on 15" wheels I think the sidewall flex is ridiculous- and that's with good, stiff sidewalled tires. But, yeah, sultan didn't seem to have too many problems running 14" wheels. It's possible, but steering feel, response, and good tire choices go out the window.
sultan
the es100 comes in 205/60-14, but it's pricey (for a 14) at $75 each. if you want 14's get 14x8 or larger and those tires. unless you want to run super short tires you need to stretch the 205/60 onto a wide rim.
if tire sizes/selection didn't suck so bad i would get some 14x10s.
