You can separate Hydrogen from water with the current of a car battery, 12 volts 10 amps. Check out this link:Haitian_King wrote:Many moons ago, I asked my chemistry teacher about using hydrogen and oxygen as fuel. Seeing as they are both highly combustible in their separate forms, I had an idea to fill a tank with water. He says that a powerful enough electrical current needed to pass through the water to break the hydrogen and oxygen bonds. I didn't know what to do after that.
I take it you need a bettery/generator powerful enough, but also lightwieght and able to be stored in an unobtrusive space. Would you need holding tanks to store the separated hydrogen and oxygen? Oxygen in a tank might be a bad idea if the car is left in the sun right?
I haven't really given much thought to fabrication. Just theory really.
http://www.water4gas.com/2books.htm
It is very interesting. I may look into it further. It is a very simple way to do what I am thinking about. I will probably try it on an ATV first so I don't blow up my Q.
