WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri May 06, 2005 9:02 am
I'm no engineer, but I rewire helo's alot. Splicing is the worst type of connection.
My favorite method for ease of work is to slide on a piece of heat shrink, then twist the wires together, then solder the two at the twist. Makes for a perfect connection. The slide over the shrink wrap and roll.
Here's a tip, needed or not, make the connections staggered, not all in the same spot. SO the wires are easier to lie back down and wrap up.
WD
