dezm45https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=37323848dfb82549b994cbb26481f958Has anyone replaced the fogs on the M45 ??Mon Nov 03, 2003 4:38 am
Postby
PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.htmlMon Nov 03, 2003 4:38 am
Yes there was thread here on that ,sometime ago.I am having trouble finding it w/ a seacrh, and cant spend too much time looking for it, at work.But its there, instructions and all.
Postby
maxnix »
https://forums.nicoclub.com/maxnix-u127.htmlMon Nov 03, 2003 4:38 am
1.) Remove the fender protector.2.) Disconnect the fog lamp connector3.) Remove nuts and slide fog lamp out of front bumper area.4.) Turn the palstic cap sounterclockwise adn unlock it.5.) Unlock the retaining spring and remove the bulb from the fog lamp.6.) Install in Reverse order.
Postby
szh »
https://forums.nicoclub.com/szh-u149.htmlMon Nov 03, 2003 4:38 am
maxnix wrote:H1 is for high beams on FY33. On Y34, high beam is a 9005. Manual confirms this.
Oops! I should have RTFM'ed the M45 service manual. The fog light is listed as a 55 Watt H3 and the high-beam is listed as a 60 Watt HB3 or #9005 (but not H1 - where did you get your info, Brian?).
I certainly would not recommend changing the low-beam on an M45, of course! They are HID Xenon's already.
