has anyone raced a 90-93 VS 94-95 Q before?
BeefCake
Car: 1990 Q45
just like the title says...
Im just curious, the 95 Q pulls pretty strong. But people say the 90-93 Q pulls harder and is faster. Has anyone actually raced these two before?
I know that the early Q's got the better transmission and the sodium filled valves and some even claimed they were closer to 300HP. What about the 94-95 Q's, are they also closer to 300hp?
If not, some of you guys should get together and RUN IT!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The 90-93 Q is slightly faster... it definitely pulls slightly harder in 1st gear past 5000, due to the twin HP peaks..... it is noticeable.....
However, Im thinking that it would be VERY close 90-93 vs 94-95 (even 96) if they all had the same transmission...
zinkie13
Car: 1992 Lexus SC300 Single Turbo
And add a y33 into the race....so no one loses! haha
BeefCake
Car: 1990 Q45
so 0-60, the early Q is faster, but topend their about the same right?
Now i really want to go and test drive a 90-93 Q. To see how it feels like.
szh
Car: 2018 Tesla Model 3.
BeefCake wrote:so 0-60, the early Q is faster, but topend their about the same right?
Probably! Having owned both a 1991 Q45 and a 1995 Q45, I can comment on this a tiny bit. The 1991 was definitely sportier. Tighter, more-precise steering, felt stronger and less scary at high speeds.
Although "scary" is a relative term here, since neither one felt out of control per se. I drove the 1991 at 145+ mph on an extended trip once and it was great! I probably would not have considered doing the same in the 1995, although I did take it to 120 mph to 130 mph without any problems.
Z
350zQ45a
Car: 350Z, Q45A
Yea, it would be nice if only people who owned both chimed in, so let me.
My 91 was clearly faster then my 94. Twin HP peaks, better gearing, different heads all are factors.
Also my 94 wasn't nearly as stable at high speeds, due to the grill being added in, and the coefficient of drag increasing.
All that being said they are both so close to each other, it's not a night versus day diff. Neither one is quick off the line
elwesso
2007 BMW M Coupe
350zQ45a wrote:Yea, it would be nice if only people who owned both chimed in, so let me.
Indeed, however the slightly taller 1st gear makes low end power just a little better..... bottom line the transmission sucks in all Qs, except the 5 speeds.....
With the tokico blues it makes it just as tight.....
350zQ45a
Car: 350Z, Q45A
The 90-93 was made with performance in mind first, the 94+ was an answer to all the whiny americans bitching about the cars best traits. It was a compromise.
You can say that is my opinion, but it's really the opinion of the motoring press, the engineers themselves, and myself
Modified by 350zQ45a at 4:54 PM 7/16/2005
BeefCake
Car: 1990 Q45
a 94-95 Q with an ECU upgrade would own a 90-93 right?
elwesso
2007 BMW M Coupe
BeefCake wrote:a 94-95 Q with an ECU upgrade would own a 90-93 right?
A 94-95 Q with JWT, all else stock, is pretty close to a stock 90-93
