drew97qx4 wrote:Personally, I think the stock sounds best.
Stock is broing.
Being that our PF has seen mag-chloride in Denver and now sodium-chloride in OH on the snowy/icey roads, I don't think the exhaust pieces will take much more. I know that exhaust pieces have an 8 yr/80k mi warranty, but replacing with something that has a bit more growl isn't too much to ask for.
I know there are two cans (front and rear) in the exhaust system. The big front can has two in/one out and is about 20" long (50cm) and the rear can is smaller and is one in/one out to the tail pipe. Which one is a resonator and which one is a muffler? Are they both mufflers?
For those that have replaced from the cats back, do you have any pictures of your setup? Are you still running two cans or did you just go with one?
Has anyone cut open the stock cans to see how they work or what magic they hold?
What would be best for less drone...straight thru or chambered. If chambered, a 2 chamber or 3 chamber design?
