quest »
https://forums.nicoclub.com/quest-u7580.html
Fri Jun 25, 2004 1:23 pm
the ca18 will give an sr20 a "run for the money", mod for mod. Look at the aussie and uk ca18 examples.... check out tweaks' mentioned above. Nuff said. Research it if you like.Did he 'really' switch to the sr because of the 'only 13sec with all those mods' ?? ..because an sr20 will not fix that problem.
While that ca/s14 had a lot more potential left in it, you'd find the heavier s14 don't run all that impressive times, with the smaller sr/ca motors... hint; torque vs wt.
