cheapazz »
https://forums.nicoclub.com/cheapazz-u97627.html
Mon Jul 21, 2008 6:17 am
HERE!! I took it on. It took me about 8 1/2 hours to do the install. My buddy at big o looked up the time in their manual and it said 7 hours. The driver side isn't all that bad, I think it took about 2 1/2 to 3 hours, it's just a matter of removing the intake to the throttle body and not having very much room to work. Most of the work is done from the top side. I think there was one bolt on the cats that was from the bottom. I didn't remove my belly pans for the install but I would recomend doing it just for the sake of less headaches while dropping nuts and wrenches and such. The passenger side is another story. The coolant line, ( a hard line) runs directly over the top of the header and must be removed along with various wires and vacuum lines. The headers I bought didn't come with any directions so I had to muddle my way through the install. Then trying to fight the headers in is no easy task either, its really tight. It helps, when you get to this point, to remove the bolts holding the cats in place. This allows some extra room for removal of the stock manifold and to help get the headers in place.
BASICALLY......if yer a wrench with some experience go for it. A novice may find himself in trouble or "in over his head".
Hope this helps some.......HAPPY WRENCHING
