Important to understand the math and work out that a return system needs to flow 2-2.5 x the amount of fuel required by the horsepwer equation otherwise the pressure is unstable and a cylinder may run lean and vary.
320HP/2=160 pounds or 26 gallons per hour or 100 liters per hour.
However this is for an A/F ratios of 12.5 not 10 as programmed by ecu to cool the pistons and cats.
So 12.5/10=125% more or 125 liters x 2-2.5= 250-312 liters per hour
Hopefully you can see a 255 liter pump barely cuts it in maintaining a steady 43.4 psi fuel rail pressure. [This works because of the extra fuel pulse damper circuit in front of rail] ............driven by the air pulses infront of throttlebody.
This all works because Q are not driven at full load for very long and their is the 25% extra richness margin to work against for pump aging and voltages drops as the pump heats up from high rpm use.
I would be nice to measure piston temperature or a surogate of cylinderhead temperature as coolant or oil temps take too long to go up due to mass of liquids.
Coolant is especially slow due to it's weight of 20 pounds [oil 10 pounds]
http://www.lindertech.com/fuelpump.htm
