sidewayz32 »
https://forums.nicoclub.com/sidewayz32-u63080.html
Fri Apr 20, 2007 1:47 am
Im new here, and i bet this has been covered a thousand times. did you search?
TT Swap Parts List.
* TT engine * Full engine gasket set * Intercoolers * Intercooler plumbing * Intake plumbing * TT radiator * TT fan shroud * TT oil cooler and hoses * New oil pump * TT A/C condenser and A/C lines * Recirc valves or BOV's * Electronic boost controller or buy a TT ECU * New EFI wiring harness: (EBC - NA harness, TT ECU - TT harness) * New PTU module * New TPS module * New EGR valve * TT flywheel * TT clutch and pressure plate * New motor mounts * All new hoses on the engine * Fuel injection hose * New oil, fuel and air filters * TT fuel pump * TT front fascia * Modify idle circuit plumbing to attach to intake hose. * Fabricate mounts for IC plumbing, radiator, and oil cooler. * Modify manual transmission bellhousing for larger flywheel
