Recall ID # 98V284000 - Equipment:Electrical:Radio/Tape Deck/Cd Etc.
Recall Date:Nov 05, 1998
Model Affected:1991 Infiniti Q45
Summary:Vehicle Description: Passenger vehicles equipped with bose rear speakers that have an integral amplifier. A conductive bridge can form between two lines of the circuit board pattern when there is accumulated electrolyte leaked from capacitor and high humidity conditions. This can close a transistor on the circuit board which causes overheating.
Consequence:This condition could result in smoke or flame and possibly the speaker catching fire.
Remedy:Dealers will replace the circuit board with a new board that has been Coated.
Potential Units Affected:28970
Notes:Nissan North America, Inc.Recall ID # 95V103002 - Seat belts:Front:Buckle assembly Recall Date: May 24, 1995Component: Seat belts:Front:Buckle assembly Model Affected: Q45Potential Units Affected: 2730462Recall Date:MAY 24, 1995
Summary:The front safety belt buckle release buttons can break. These red plastic release buttons are marked "press." If a button breaks, pieces can fall into the buckle assembly causing the buckle to operate improperly.
Consequence:The safety belts would not provide adequate protection to an occupant in a vehicle crash.
Remedy:Owners should promptly check the condition and operation of both front safety belt buckles and carefully inspect the red release button for any breaks or cracks. They should ensure that both buckles are operating properly by inserting each latch plate into its buckle,tugging on the belt to make sire the latch is securely locked, and then pressing the release button. The latch plate should pop out of the buckle when the button is pressed. If either release button shows a sign of breaking or cracking or if either buckle fails to operate properly, owners should promptly contact their authorized dealer to schedule an appointment to have the buckle replaced or repaired free of charge.
Potential Units Affected:2730462
http://www.motortrend.com/cars....html
