Why don`t you just use an invisicord?
Though, you won`t be able to use remote button.
zer...stall
Invisicord wire is the same use for V1 and Escort/Bel
Invisicord yellow WIRE goes to BROWN wire of the Rearview MirrorInvisicord Black WIRE goes to the Black wire of the rear view mirror.
I installed mine in 10 sec.
Here is where you can get it.
http://www.invisicord.com/order.paypal.html
Make sure you order that extra service for G35, 350Z, FX35 Upgrade.
The metal tips that go to the Rearview mirror harness are a lot thinner
than normal. From my experience, you wedge that flat side of the tip on
the back upper part of the stock rear view wire. SEE PIC BELOW.
You only need 8" wire if you`re installing it like mine.
I wanted a clean install, so I used zip tie to cover the exposed thin wires.
BTW, if you have that sensor or laser showed on Jmess installation, you probably would do the installation like he did. My ex35 didn`t come with that laser feature.
Modified by AWGD8 at 2:40 PM 3/8/2009
