Has anyone had a problem with the gas gage on Nissan truck?
truckboy
We have a 07 Nissan Frontier the gas gage has stopped working properly,one other person we know had the same problem I want to know if any of you have had the same issue? :gotme :cry: :ohno: :facepalm: :sad:
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
I wonder if there may be a recall or something. Have you asked a service adviser or parts person at the dealer to see if they've many others with the same issue?
waynegarcia13
Car: 1997 Nissan Hardbody Pickup 2wd
2.4L: custom made cold air intake,
oil cooler, suspension lift, exhaust,
upholstery, stereo sys., paint
You probable broke the floater or it came off. Either way you have to have the tank dropped. And no that is not a recall or common problem that usually happens when it is driven hard or a sudden hard bump at a weird angle or it may just be a bad part.
Dana_15
Car: 2008 Infiniti G35X
2010 Nissan Frontier CC LB 4X4
RECALL: 2006-2008 Nissan Frontier
NHTSA Campaign Number: 10V075000 www.nhtsa.dot.gov
Manufacturer NISSAN NORTH AMERICA, INC.
Recall Date: FEB 26, 2010
Potential Number Of Units Affected: 80689
Description FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK
Summary NISSAN IS RECALLING CERTAIN MODEL YEAR 2006 AND MODEL YEAR 2008 FRONTIER, XTERRA AND PATHFINDER VEHICLES. THE MOLDED FUEL TANK SHELLS CAN DEFORM, CAUSING THE FUEL SENDER FLOAT ARM TO CONTACT AN EMBOSSMENT MOLDED INTO THE TANK SHELL CAUSING THE INSTRUMENT PANEL FUEL GAUGE TO SHOW THAT THE VEHICLE HAS APPROXIMATELY ONE QUARTER TANK WHEN THE FUEL TANK IS EMPTY.
Consequence THIS COULD CAUSE THE VEHICLE TO RUN OUT OF GAS AND STALL IN TRAFFIC, INCREASING THE RISK OF A CRASH.
Remedy DEALERS WILL REPLACE THE FUEL LEVEL SENDING UNIT INSIDE THE FUEL TANK WITH A NEW ONE THAT HAS A MODIFIED FLOAT ARM. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE MARCH 22, 2010.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
My 06 Frontier had the same problem. Took it to nissan and they replaced the sensor with a new part. Total cost $.00
Just make an appointment, it should still be under warranty
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Yeah, there's lots of info on this, it affects Frontiers, pathfinders and xterras. My 2005 isn't included even though it is showing all the problems (doesn't work.) Your '07 is definately though.
