Yep AWD requires pulling motor for both manifolds. RWD you can replace the passenger side manifold without pulling motor. Yeah not very maintenance friendly.CorbinM56x wrote: ↑Thu Sep 07, 2017 8:01 amI'll be looking into those manifolds!! I'm guessing the exhaust port configuration maybe different! But worth looking into!! Thank you!! But regardless I think you may still have to pull the motor to replace them!! Great design Infiniti!!!
The truck manifolds are complrtely different. Our cars essentially have tri-y shorty headers before the headers.CorbinM56x wrote: ↑Thu Sep 07, 2017 8:01 amI'll be looking into those manifolds!! I'm guessing the exhaust port configuration maybe different! But worth looking into!! Thank you!! But regardless I think you may still have to pull the motor to replace them!! Great design Infiniti!!!
Is cataclean a product we should run to possibly lengthen the life of the cats? Meaning to run it at 65K or 85K miles, etc.CorbinM56x wrote: ↑Tue Sep 05, 2017 8:08 pmI've got a tic over 134,000 miles on my M56x and pulled a code P0420 which is the catalyst below threshold thing! I bought a bottle of cataclean and followed the directions. To my surprise the SES light went out within 20 miles, and remains off! But I'm sure it's not a permanent fix! And I've heard that if the manifold cats go bad it can be sucked back into the rear cylinders on both banks!? Really don't want to pull the motor and spend 700 a piece for both cats!! Wonder why I can't just take the Y pipe off and gut them?? Anyone ever do it?
Would not have helped I feel in my case. The catalyst core simply melted away.knelson wrote: ↑Thu Sep 07, 2017 6:40 pmIs cataclean a product we should run to possibly lengthen the life of the cats? Meaning to run it at 65K or 85K miles, etc.CorbinM56x wrote: ↑Tue Sep 05, 2017 8:08 pmI've got a tic over 134,000 miles on my M56x and pulled a code P0420 which is the catalyst below threshold thing! I bought a bottle of cataclean and followed the directions. To my surprise the SES light went out within 20 miles, and remains off! But I'm sure it's not a permanent fix! And I've heard that if the manifold cats go bad it can be sucked back into the rear cylinders on both banks!? Really don't want to pull the motor and spend 700 a piece for both cats!! Wonder why I can't just take the Y pipe off and gut them?? Anyone ever do it?
Yep, mainly DI engines for valve guide lubrication...it's normal to use some oil. The 5.6 seems to blow excess oil though, IMHO. I empty both of my cans every 1000 miles, close to 1/3 cup. The last 1000 mile pic I posted was after a 5W30 Mobil 1 oil change. It looked darker than it was.CorbinM56x wrote: ↑Thu Sep 07, 2017 8:01 pmI had one on my 89 supra with a 1jz and a 60-1 turbo on it pushing 18psi!! Only had to empty it maybe once every other oil change!! And that was at 3,000 miles! I did notice on the M that immediately after oil changes maybe like 500 miles or so it looked very dark!! Is this also common on DI motors!?
Thanks DFW. Might you have pics of the truck manifolds by chance?DFW2011M56S wrote: ↑Thu Sep 07, 2017 6:33 pm...
Not even close. The cars tuck in much tighter to the transmission than the trucks. In fact they bolt to a brace that ties them into the engine and trans near the bellhousing.EdBwoy wrote: ↑Fri Sep 08, 2017 6:59 amThanks DFW. Might you have pics of the truck manifolds by chance?DFW2011M56S wrote: ↑Thu Sep 07, 2017 6:33 pm...
Despite the style difference, are the head-to Ypipe dimensions any close between vehicles?
It is a VK56 thing all together. Both of my Titan VK56DEs used just as much oil and 90% of it was getting carried through the PCV valves.CorbinM56x wrote: ↑Thu Sep 07, 2017 7:49 pmI believe cataclean must work by reducing hydrocarbons, therefore tricking the O2 sensors thinking the catalyst is functioning properly!! So to me it's a mask!! And don't trust it at all!! Also I think the main reason these cats fail is from burning oil! My winter vehicle a 2005 Toyota 4Runner sport also had a cat go bad due to a small head gasket leak. Catalyst don't like coolant either!! But that was many years ago and still haven't fixed the head gasket!! Runs great to this day!! Now by design Nissan may have made a motor that burns 1 to 2 quarts of oil between changes because of no fuel going over the intake valves!? Maybe to help with lubracation of the seats!! Not really sure on that! But my engine uses oil!!! You can't see it or smell it but she drinks!! Usually 1 to 2 quarts between changes!! But that's me driving like I stole it!! In which I did for $10,000!!! So my plan is to do exactly what DFW did and remove said cats and Uprev to emulate the O2 sensors!! I don't like the fact that Nissan can make an engine that rocks and also drinks oil!! Most importantly on a $70,000 dollar luxury sports sedan!! Just my 2cents!!
Well, there goes that hope. Thanks for the infoDFW2011M56S wrote: ↑Fri Sep 08, 2017 6:15 pm...Not even close. The cars tuck in much tighter to the transmission than the trucks. In fact they bolt to a brace that ties them into the engine and trans near the bellhousing.
There are several styles on Ebay, Amazon, etc. No need to fab one unless you just want to. They range from $20 for a plain jane trap to $200 for a machined diffuser/filter type that you can take apart. I found mine on Ebay. Since the 5.6 has a dual throttle body intake with two PCV valves, I opted to go with 2 cans. I posted a thread if you scroll down the forum. Yeah I paid a little more but I liked the style and ease of maintenance, plus I was able to use the Camaro mounting brackets to mount them to the back firewall.CorbinM56x wrote: ↑Fri Sep 08, 2017 6:22 pmI'll fab up a catch can!! One or two? Which would be easier and more cost effective?
I have thought about moving the PCV valves myself. Because the VQ V6 is so commonly force inducted they make a fitting that screws in place of the PCV valve in the cover and converts to AN line. I have considered running both into a seperator filter and running a single larger inline PCV valve T'd into the stock intake manifold fittings. I feel bigger fittings and tubing with lower velocity may pull less oil.armybrat wrote: ↑Sat Sep 09, 2017 7:14 amThere are several styles on Ebay, Amazon, etc. No need to fab one unless you just want to. They range from $20 for a plain jane trap to $200 for a machined diffuser/filter type that you can take apart. I found mine on Ebay. Since the 5.6 has a dual throttle body intake with two PCV valves, I opted to go with 2 cans. I posted a thread if you scroll down the forum. Yeah I paid a little more but I liked the style and ease of maintenance, plus I was able to use the Camaro mounting brackets to mount them to the back firewall.CorbinM56x wrote: ↑Fri Sep 08, 2017 6:22 pmI'll fab up a catch can!! One or two? Which would be easier and more cost effective?
I looked at the GT-R kit link you posted. Looks like a sweet rig! It's already set up for a dual intake, plus it has the check valve built in for drainage. I like the oil dipstick mod for the drain hose. I would use the AOS as intended, instead of teeing into one valve. The third inlet port would have to be plugged (GT-R had a PCV valve at the rear of the block in addition to the turbo ports), a custom bracket would have to be made for mounting, the 8AN hoses would have to be modified to fit the M56 intake and PCV valves, and the drain line would have to be tied into the crankcase or oil pan somehow for truly maintenance free application. The M56 PCV valves looks identical to the GT-R one (same outlet diameter) so I feel that they should be adequate.DFW2011M56S wrote: ↑Sat Sep 09, 2017 10:39 amI have thought about moving the PCV valves myself. Because the VQ V6 is so commonly force inducted they make a fitting that screws in place of the PCV valve in the cover and converts to AN line. I have considered running both into a seperator filter and running a single larger inline PCV valve T'd into the stock intake manifold fittings. I feel bigger fittings and tubing with lower velocity may pull less oil.
