If your car is not pre-wired. you will need to run a wire. If it is, that will save you a few min in the installBigBodyV wrote:ok tht will work but dont they also have already pre wired kits?
If you have the wires.. you will need the "kit" lights, bezels, and turn signal switch. ~300 bucksOR.. you can get a simple aftermarket kit and just keep rockin'NEEd2Sp33d wrote:i have a SL. i found the wires the other day. but my question is:
is it plug and play? how do you turn the lights on? do they turn on when you turn your headlights on?
I have the OEM foglights, I like them better because they look clean and go with the car quite well.Francesco wrote:If it is prewired as my Versa S was, you will need to replace the turn signal/light stalk in order to have the built in relay energize the existing wires for the fog lights. Very easy to replace the stalk in about 10 minutes. The fogs are programmed in the computer to only work with the low beams on.
Frank09 Versa S sedan MT-6 with 5700 miles
I bought the $20 walmart kit and hooked them up to my HID's. 1hr and they are good to go.NEEd2Sp33d wrote:i have a SL. i found the wires the other day. but my question is:
1drumr wrote:you got any pixs man
not my pix though.versa s 2007 wrote:i did some fog lights from walmart, picked up for 20 bucks and wire everything was like 34 bucks and its the big round lights fit so good and look nice
