Has anyone ever used a FMU High Pressure Fuel Regulator
valkyie
Car: nissan 300zx na
Hey Guys, I need some advice about fuel management units that are installed on the return line of the fuel system to increase the pressure of the fuel injectors. I am planning on running 6 to 7 PSI of boost on my NA motor and I want to be able to increase the output of the injectors instead of buying larger injectors.
Has anyone ever used, installed one of these regulators on their Z?
ztommyx
i have one.
aeromotive fpr. can you spot it?
valkyie
How is it tuned? How much of an increase in injector performance is it making? Is this something I can install myself or should I go to a tunershop to have it installed?
ztommyx
are you boosting your NA?if not, no need for a fpr...
it's easy to install, just install feed and return line.
valkyie
Yes I am planning on boosting it to 6 PSI and if the fuel injectors cannot supply enough fuel I will use a FMU.
