Has anyone ever heard of Z1 Iconel Tubular Manifolds?
addicted4life
Car: RHD '93 Fairlady 2+2, 3076s, Haltech, & Hoosiers. Go baby, go.
Apperantly Z1 made these a little while ago but stopped production because of cost. If I could get my hands on a set of these it would save me a lot of time and material having to fabricate for my new turbos and the wastegates. Maybe you know if someone with a set that would be willing to part with them?
Thanks for any help
Brad
vulcanrush
Car: 93 300zx n/a to tt
specialtyz made them, not z1, the inconel manifolds.
not just the cost, but they would also crack after a while.
300ZXttZMAN
+1 ^
For some reason the Z32 only likes cast turbo manifolds.
addicted4life
Yea but after a little mocking up I'm going to need tube style or similar. That or I seriously hack up my stock manifolds to fit the t3 and extra pipe for my waste gates! We have several ideas in mind but these would save any possible hack jobs I might have to resort to.
Anyone in particulat at SZ that would know about finding a set of these? Don't you have a contact there mark that your always dealing with?
addicted4life
vulcanrush wrote:specialtyz made them, not z1, the inconel manifolds.
Pretty limited as I stand now, Trying to see all my options and not have something that looks hacked
300ZXttZMAN
I always deal with Greg. I talked to him earlier today so he should be there.
addicted4life
Found a set here in canada, of all places, for dirt cheap so picked up up. Should be here in 2-3 weeks at the slowest cheapest shipping available haha
300ZXttZMAN
Good luck. Like stated before, the manifolds will crack. Its not that they are bad manifolds its just something about our engine not getting along with tubular manifolds.
Maybe it has something to do with the fact that there are only 3 cylinders per manifold? Maybe because of so much heat in such a little place? :gotme
Good luck man... This is where the phrase "do it right the first time" comes into play. You will find yourself having to pull the engine to replace manifolds.
addicted4life
Can you suggest an option with enough space or an exsisting location for wastegates?
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
You can reinforce them with stainless bar. Get flex pipes on your test pipes to help.
addicted4life
Like gussets or rods to support the weight of the turbos?
BigTDogg (MA)
Correct.
addicted4life
Thank you
I'm going outside of the box with my build, not so much just bolt on anymore. Input helps!!
