tyrannix wrote:the 1 piece aluminum from enjuku (the driveshaft shop actually) is 11 lbs and supposedly rated for 800 ft-lbs
i have no doubt that they can make you one shorter or longer for a just a little more, thats what im going to end up doing when i drop the CA into my ae86
CJ
I tried 3 times to get a decent driveshaft from those people. Every time it was too short and not balanced (big headache). I had one made from a shop in Ontario Ca. that came out perfect the first time for the same cost -shipping.Another thing to think about is vibration. I am also running subframe collars along with the one piece driveshaft, so all the vibration that comes from the motor gets transferred to the transmission to the driveshaft to the differential to the subframe to the frame to my seat.
If its your daily driver, may I suggest that the center support bearing on the stock S13 driveshaft is amazing at dampening drivetrain vibration.
