S14KoukiMonster »
https://forums.nicoclub.com/s14koukimonster-u36640.html
Mon Jan 30, 2006 11:56 pm
Just curious to see if anyone's ever had their clutch linkeage break? I was driving home, shifting into 3rd when all of a sudden "pop", my pedal dropped to the floor. The piece that broke connects the pedal to the pushrod for the clutch m/cyl.( U-bolt-shaped, threaded onto pushrod, connected to pedal w/pin), and it broke at both right angle bends. Should be easy enough to fix with a mig or tig welder, so I thought I'd reinforce it by welding a washer (with a slightly larger hole than the pushrods diameter) to the side facing the firewall, and grinding and filing it to shape. Anyway, has this happened to you? I would doubt I'm the only one this has happened to, especially with a stock clutch.
