deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Mar 21, 2004 3:25 pm
search for "individual throttle bodies" and click on that recent post by midnightsliding.
custom or expensive manifold is basically a requirement (unless you already have a nms carb manifold, they are now about 500 dollars). This will allow you to run dcoe/mikuni phh style, efi itb's, available in proper configuration for the ka from TWM and others.
You could custom make your own (i am assuming btw that you have ka24e) using a fwd stanza intake to start. I am doing one like this, as well as using an altima one for my ka24de setup. the fwd manifolds come out from the head at a much better angle.
My setup is nearly complete, 50mm tb's, 330cc injectors, edis distributorless ignition, full standalone fuel and spark control. Im going to buy some larger injectors in the future. I am making manifolds for both e and de to eventually try.
