Sorry, I made that confusing. I meant to say that the only Pathfinder at my local junkyard is a 2000.
http://www.courtesyparts.com/-c-4700_47 ... _4870.html
Based on the exploded view it appears both heaters are behind/under the the cushion, not directly under the first layer of material. Also the back heater seems to hook on top at the headrest inserts by its two holes. I suppose the bottom heater can't really move all that much since its pinned under the foam so I wouldn't be surprised if it didn't have any mounting. Based on the fact that they're behind the foam, I wouldn't think that the seat material leather or fabric would make much of a difference since its not direct contact with the element and the flashpoint of say cotton is on the order of 400C.
EL-211 is confusing to me how they share the same gray 3 pin vehicle harness plug (B5) but also have another two pin plug that connects the two (B405). I don't understand that since there is only one plug vehicle side. For that to work, I would expect 2 plugs on the seat cushion pad (B405 and B401) and one for the seat back (B405), but in the exploded view it just shows one plug per pad?
I'm a little bummed I may need to disassemble the seats to get the pads underneath the foam.
