Has anyone changed their gearing?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I am also looking into changing out the differential gears. Not just to a LSD, but a lower set of gears. I'll trade some of the top end that I never see for some bottom end that will be used.
Any clue where to find? I haven't searched yet, but am going to start looking. If anyone knows of a lower geared LSD diff for sale LMK.
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
I saw some 4:11s for the 350Z that I assume would work for a G. I think they were NISMO. I'll bet they fit.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
change your overall diameter of your wheel/tire combo.
thats what I did? Now 140 mph on the speedo is really 132 mph so my gearing is about 5.8% taller.
I'm running 235/45/17's I'll probably try 245/40/17's next
Beancooker
I'd rather have the benefits of a limited slip, combined with lower gearing. If the car topped out at 120-130 but I gained a lot more in the bottom, I'd be glad to make the trade. It's easy to find a LSD, but no one states the gear ratio, which makes me believe that it would still be stock ratios.
goneracin
Car: 2004 G35X Sedan 1990 Mustang conv.
Looking at the specs of the different models at infinitihelp, it looks like the 08's stepped up the gear ratio from 07. I wonder if you could swap a newer one in?
Beancooker
I was thinking of something more along the lines of what Bob had pointed out. A Nismo set that 4.11 would be alright. Plus I would rather have a clutch style LSD, than a VLSD. I know it would be a little louder, but it's worth the sacrifice.
goneracin
Would you be sacrificing traction with the clutch style set up or is the traction control still usable?
Beancooker
Traction control would still be usable. This would just transfer power from wheel to wheel, at the differential, instead of the ECU telling the brakes to slow the spinning wheel.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Never mind what I originally said. I need to search before I state...
Here you go.
http://www.forcedfed.com/350z/lsds/cusco.html
Even more options!!!
http://www.350z-tech.com/zwiki...tials
Beancooker
Thanks Nate, but I already found those. I also found that same diff for $773.
What I did find out speaking to the guys at Covina Nissan is that all diffs ship without the final gear. You re use the final gear from your car. A final gear costs around $1300.
Also, the difference between running the stock final gear of 3.35 or 3.7 depending on which drivetrain you have, is also the difference between 18mpg and 6-10mpg.
I was explained that with a 4.11 gear in the G35 or 350z. that top speed would be between 80 and 100. At 75 I would be in 5th and around 5k rpm.
The LSD will make a difference, since all the torque will be transferred to the road, however it also comes with the cost of clunking, and chatter.
Maybe later down the road.
Sentientbydesign
96 I30 - Sold
Ouch!
Not worth it IMO.
I started checking at what speed each gear redlined. So far:
1st...not sure (I think its around 35 )
2nd: 60MPH
3rd: 83MPH
These are rough estimates, but pretty close to accurate. I'm assuming 4th is in the 100-110 area, 5th probably sits around 130 and no clue with 6th. I doubt I can peg the speedo with the 19s.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Too bad man. Sounds like a lotta money for the negative that comes along with it.
Guess you gotta just go with exhaust instead!
Beancooker
Sentientbydesign wrote:Ouch!
Not worth it IMO.
2nd: 60MPH
3rd: 83MPH
I have an autotragic, so my gearing is even higher, I do believe. I hit the freeway on the way home, so I'll see where I get at redline.
RiskyBusiness
Car: 2006 G35 Coupe 6MT
At what RPM do you consider it redlining?
TurboDurbo
Car: '07 Infiniti G35 Coupe 6MT
According to the manual of my 07 Coupe 6MT
1st: 352nd: 603rd: 904th: -
Sentientbydesign
96 I30 - Sold
TurboDurbo wrote:According to the manual of my 07 Coupe 6MT
Interesting. I just checked 1st yesterday and it redlined at 40-41. Second at just around 60 and 3rd at around 83ish.
Wonder if the difference in MY between yours and mine makes a difference.
RiskyBusiness wrote:At what RPM do you consider it redlining?
7k on my 6mt coupe (that's where my redline begins). I won't take it past there intentionally.
Jacko3
TurboDurbo:
Mine too! 076MT Coupe. I think I have taken my first gear up to 40 miles per hour, with the mods on it.
Anyway, the beauty of the G-coupe 6MT is the fail safe or cut off from excessive revving. So, technically, you really can't destroy the car or abuse it.
Beancooker
When the rev limiter kicks in...??? LOL. About 7k, give or take a few clicks on the tach. Nissan is well known for their terrible calibration of the tachometer. The ECU actually is what starts the rev limiter, not the tach. So all of them redline at the same RPM, just looks different on everyone's tach.
Hope that makes sense.
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Jacko3 wrote:TurboDurbo:
Well Jacko... he he, let's just say, "less abusive" lol
FlyG35
Car: 2003 Infiniti G35 Coupe
With that said, I have an '06 transmission in my '03 G35 Coupe MT6. The previous owner said he chose that because it's a better transmission and has 3 synchros per gear instead of 1 synchro, plus it has a closer/shorter gear ratio. My question is would this be why my Rev-Limiter kicks in at 5,600 instead of 6,600 according to the tachometer OR do I have another issue? Cause the car runs GREAT other than that.
