Has anyone changed the CVT fluid? What Km's should it be changed?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Driving Instructor
Car: 2007 nissan versa SL CVT Red
Hi,
My car has now 165 000 kms and I was wondering when the cvt fluid needs to be changed? I looked at the dip stick and you can't remove it.
Thanks ahead of time!!
Gerry
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
I had my first V's CVT fluid changed at 90,000 mi (145,000 km). The service manual said if you're driving under dusty or muddy conditions to replace it every 60k miles if you weren't using the Nissan computer to check on it. It doesn't say when to change it under other conditions, whether Schedule 1 or Schedule 2 - just to inspect it.
Since I don't drive under those conditions very often I just figured I'd play it safe. Plus, I had the work done at my favorite mechanic, so he didn't have the CONSULT II computer to check the CVT fluid.
NODES
Car: 2007 Nissan Versa SL (Blue)
Automakers consider Canada harsh conditions, so it should be done at 60K.
Bubs daddy
ABS, CVT
Maybe the owners manual has the information...
NODES
Bubs daddy wrote:Maybe the owners manual has the information...
marlin29311
Car: 2008 Infiniti G35x
Take the car to your Nissan dealer and have them run the CVT diagnostic - there is test that can be run that checks on how the fluid is doing - basically they pull a degredation number and compare it to the acceptable level...if it's worse, they change the fluid. If not, your fluid is good to go still.
NODES
marlin29311 wrote:Take the car to your Nissan dealer and have them run the CVT diagnostic - there is test that can be run that checks on how the fluid is doing - basically they pull a degredation number and compare it to the acceptable level...if it's worse, they change the fluid. If not, your fluid is good to go still.
Sophisticated the Nissan are *yoda voice*
Return to “Versa Technical Discussions”
