zest2live »
https://forums.nicoclub.com/zest2live-u64792.html
Sun Feb 03, 2008 3:21 pm
I just had to pull the EFI harness through the firewall to check for a bad wire. I needed to pull the blower unit out to do this, and yes to pull the blower unit I had to pull the cooling unit which meant breaking the a/c lines open at the firewall.
However, if you are just replacing the blower motor, it looked to me like you could just remove the 4 (8mm (I think) bolts) (on the metal circular band) and the blower motor should drop out. I believe you'll also have to remove the metal framing for the glove box, but this is also just 4 bolts that are easy to get to once the glove box is removed.
