Has anyone actually had a coilpack randomly go bad?
exode
Car: 90' 240 w/ 400hp SR20DET
Just curious, I'm not sure if this is a myth or not. I'd really like to find something else wrong than buying a set of 4 new coilpacks, but if you guys have had coilpacks go bad on you then it's just what i'll have to do.
T-rev
yes. I was having a misfire issue for a while (I think it was a sketchy coil pack) because after a month or so one just up and died on me. Not fun, you are now running on 3 cyl. Plus they are a nightmare to source.
I heard somewhere that heat does them in but I cant confirm, my engine gets hot like a mother, but I guess thats just what aluminum does
CMG
Car: 1989 240sx Hatch w/ Redtop
Yes they go bad, and heat can be a comtributing facotr.
efrain240sx
Car: 1992 nissan 240sx HB
Yup one of mine went dead out of no were, good thing I had an extra set laying around
jasonkg
Car: 1991 240sx
Yes, just recently I was stumped on this very issue. I had a coilpack go bad and it took a high performance shop a couple days to figure out the problem. My car was studdering under boost and I spent lots of time and money trying to fix it on my own.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
T-rev wrote:yes. I was having a misfire issue for a while (I think it was a sketchy coil pack) because after a month or so one just up and died on me. Not fun, you are now running on 3 cyl. Plus they are a nightmare to source.
Same thing here
efrain240sx wrote:Yup one of mine went dead out of no were, good thing I had an extra set laying around
Same thing here
exode
cool well i have all the honda shops telling me coilpacks don't go bad, than i have sr masters telling me they do.
I think I'll just chance a new set of 4 coilpacks =o
95silvia14
Car: 1995 240SX, 1993 s13 coupe
if you want i got 4 good ones off my car ill sell you for 125.00+ shipping
exode
check your email
redtop91
I guess I should rephrase. My coil pack harness went bad, not the coilpacks themselves. If he falls through on the coilpacks I have a set as well.
midnightracingsr
Ok came across this thread and I have a few Questions. The studdering im experiencing in my car is around 4k rpm and levels out after you give it more gas. Just wanted to make sure the symptoms you guys were experiencing where the same so I could figure it out without changing EVERYTHING.
jasonkg
Car: 1991 240sx
This was my exact same problem as what you decribed. I changed out over a few hundred dollars worth of parts before I got fed up and dropped it off at a shop. It took the shop over a day to isolate the problem. The coilpack costed me less then $30 dollars shipped. I recommend just buying one coilpack instead of the whole set because more then likely all four aren't bad. It might be a little more time consuming with one coilpack, but it will save you some loot at the end of the day. This is more then likely your problem. Good luck.
