RM12577 »
https://forums.nicoclub.com/rm12577-u76065.html
Mon Dec 08, 2008 1:13 am
things that need done are more fuel, about 30% more but you will need to set up something for tuning and get it dynoed to get the exact amount needed, as well as upping the boost, though it is not required, it would definitely help to make it more efficient. E85 is like 105-108 octane gas but it needs to almost flood a motor to run right. If you just want to run it in your car without mods, don't go over half a tank or your car wont want to idle and you will be running quite lean, and dont up the boost past 12psi unless you plan on getting it tuned for the booze.
